Project data & BIM
Zone labels in section
Paul King
Mentor
Hi, just wondering how people avoid manually labelling spaces again and again with every new section cut through a model?
Given that zones can now appear in sections, is there any reason that zone labels do not?
What am I missing?  What is best practice here, other than manually applying zone labels?
PAUL KING | https://www.prime.net.nz
ArchiCAD 8-29 | Twinmotion 2025
Windoze 11 PC | Intel Core Ultra 9 285K | Nvidia Gforce RTX 5090 | 64 GB | 2x4K monitor extended desktop
Do the various posts in this thread answer your question?
https://community.graphisoft.com/t5/Document-Visualize-forum/Show-Zones-in-Section-or-Elevation-Arch...
5 REPLIES 5
Thanks Karl
Now I just need a way to word wrap space names in zone labels for small spaces
Because it is a label, you should be able to simply stretch it.
Thanks Barry
I am not seeing any stretch handles on the zone label object
Sorry, I forgot I set up an 'Autotext' label to show just the zone name, saved that as a favourite and have that associated to my zones.
So when I place them it is actually an autotext label added and not the 'Zone Label'.
Great for just showing the names.
And don't forget you can manually add other labels and have them in different layers, so if you also need the full 'Zone Label' you can also add that.
