Project data & BIM
apply materials to a layer?
jespizua
Hello!
Is there any way to apply a material to a layer compound of diferent elements?
Thanks in advance and cheers.
osx 10.14 | archicad 22 | cinema4d 18 |
Dwight
Please clarify your question.
Dwight Atkinson
jespizua
Hello Dwight, thanks for your quick reply.
I will try to explain better. Well, i have to export from archicad to c4d using the exchange plugin, within export option i have two option : by class or by material. The option i need is by materials, but in my archicad file i have all organiced by layer. The problem is that i have different element in each layer(walls, beam,complex profiles...) and if i select one layer an apply a material to this layer only a few elements change . I´m working in a big file and can´t change one by one. Maybe i´m making something wrong, what i do is: 1_find and select command and select the layer i want, 2_ go to the infobox and change the material apply to that element. Is this the correct way to do this? is there a workaround to solve it?
Thanks for your time.
