atributes transfering
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2018-09-09
05:13 PM
2023-05-20
12:04 AM
Gordana Radonic
2018-09-09
05:13 PM
How can i copy and apply not all of parameters but only some of them?
For example i have 2 slabs one above the other one on different levels.
If i change appearence of material in one and than i want to change it in the other one i can not do it with
syringe because it will change the level position. So how can it be donet?
Solved! Go to Solution.
Labels:
- Labels:
Attributes
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2018-09-09 05:44 PM
2018-09-09
05:44 PM
Under Edit Menu -> Element Settings -> Element transfer
Create a new set that only transfer surfaces.
With the syringe selected before clicking on the object move the icon over the blue box to the right and click on it (do not let go of the keys you are pressing on the keyboard) and select the Transfer Setting you created for "surfaces only"
Eduardo Rolón AIA NCARB
AC28 US/INT -> AC08
AC28 US/INT -> AC08
another Moderator
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2018-09-09 05:44 PM
2018-09-09
05:44 PM
AC28 US/INT -> AC08
AC28 US/INT -> AC08
another Moderator
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2018-09-10 08:39 PM
2018-09-10
08:39 PM
Thanks that help
