Project data & BIM
autosave files and folder. can i delete them?
jl_lt
Ace
Hi. Last time i checked i have 14 autosave folders, each of them between 2 and 3 Gbs.  So they take a good chunk out of the already stressed SSD in which Archicad is installed.
Can i deleted some of these folders? or can i reduce the number of these folders? even half could greatly help.
Thanks
AllanP
Yes you can.
in older versions of Archicad, if there were too many autosave folders, then Archicad would not open until you deleted some of them.
only delete them if there are no copies of Archicad running and you haven't had Archicad crash that day.
these folder are located in the user folder/Graphisoft on a PC.
I have been using ArchiCAD continually since ArchiCAD 4.5, 4.5.5, 5, 5.1, 6, 6.5, 7, 8, 8.1, 9, 10, 11, 12, 13, 15, 18, 21, 22, 25, now testing 28
Member of Architalk since 2003, but missed the migration to Graphisoft. Melbourne, Australia
AllanP
Yes you can.
Hi! Thanks a lot!
