bugs in v11
weirdeness in all its glory:
i select a wall (say) and a drag it somewhere and as soon as it's done that it automatically deselects itself. This starts to happen when i have trace reference on.... and when i turn it off it still happens. and they only way to stop it from happening is to go to my view map and double click on a view and so 'reset' whatever it is that it 'resets'
it seems to only happen when the trace has been set from the view map (yes i read the previous posts about this) btw, using the project map is just as slow for me (slower than gost story ever was) but at least the above weirdness doesn 't occur. Saying that, because i normally navigate using the view map, the same layer combo will be used for the active view as well as for the trace view. So. this is a bug, right?
0 Replies 0
