Project data & BIM
can't change line type in Archicad 15
cgrimley
My whole office has complained to me (the CAD Manager) that they can't change the line type in 15. I've noticed it too, but only on occasion, sometimes I can, sometimes I can't. Either way its a bug and needs some fixing. Has anyone had a similar experience in 15?
UPDATE: Apparently the fix is to delete some unused line types in Attribute Manager. We had about 80+ line types, of which about 40 were brought in from xrefs and weren't being used. The project is in teamwork and this fixed it for everyone working on the project. I still think its some sort of bug.
Casey Grimley
AC24
iMac Pro (2017) - macOS 10.14.6- 3.2GHz Intel Xeon W - 32GB RAM - Radeon Pro Vega 56 8GB
7 REPLIES 7
David Maudlin
Casey:
One other thing to check: if the element is assigned to a Renovation Status that is set to Override in the Filter Settings, and the Renovation Override Style uses Line Type as one of its attributes, then only that Line Type will be used on the element regardless of its setting in the Info Box or dialog box. May not be the issue in your case, but something to watch out for.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
AC29 USA Perpetual • Mac mini M4 Pro OSX15 | 64 gb ram • MacBook Pro M3 Pro | 36 gb ram OSX14
vfrontiers
The first thing I did was create a RENOVATION FILTER .... ALL AS IS...
First thing I check for when things look graphically awry.
Duane
Visual Frontiers
AC25 :|: AC26 :|: AC27
:|: Enscape3.4:|:TwinMotion
cgrimley
@David, That was one thing I checked because I found that out with some walls, I couldn't figure out why they were dashed and gray. Then I remembered the renovation filter. I've received a couple complaints from other drafters in our firm also.
Ever since we deleted the mass amount of unused line types we haven't had an issue.
Thanks!
Casey Grimley
AC24
Laura Yanoviak
This is a great idea -- especially when migrating a project to AC15 and/or when you won't be using the filters. Too bad GS didn't think of this and have all Viewpoints default to "ALL AS IS" instead of "Existing."
vfrontiers
Peeve #3298....
Nice new Renovation Filter list and all..
But since the names don't match what I want.. And since I change my mind all the time...
Did you know that simply RENAMING a filter will cause it to show as MISSING in all the VIEWS that use it! Ugh... to my knowledge this doesn't happen with any other setting in AC....
So now I'm going back and finding all the views that used them and re-linking...
Duane
Visual Frontiers
Laura Yanoviak
Uggh... sounds like another 80% new feature...
Actually, we should be thankful that this might be the only one left that has this issue...
This "Missing" business has been a long-time complaint. Through AC 14, if you renamed:
1. Layer Combination
2. Pen Set
3. Model View Option
those things showed up as "Missing". In 15, all views show the new names! šŸ™‚
So, let's hope for a hotfix that will make the filter names correct themselves as well.
AC 29 USA and earlier   ā€¢   hardware key   ā€¢   macOS Taho 26.1 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
