Project data & BIM
classifications issue
ananas
Hii!
I added a new property in Archicad so that I can add elements to "new" or "sekundar" classification.
Somehow on the list some elements that are in "sekundar" classification category it shows as: "not defined".
Even if I change that property to new, nothing changes.
Is it possible that there is some Archicad bug or did I do some mistake somewhere?
Thank you
Jonas Krieg
Hello tjasa
No idea why it's not working. But I would maybe rather use a real Property ("Eigenschaften-Manager") and not a Classification ("Klassifizierungs-Manager"). Be careful to assign the property to your classes (screenshot pt. 5).
ArchiCAD 27
MacOS 15.0
Jonas Krieg
Hello tjasa
ArchiCAD 27
MacOS 15.0
Thank you for your reply! To avoid issues, I will use Eigenschaften-Manager next time. For now I just exported the list to excel and adjusted it there. 🙂
