RWARCHPC
default value for window schedule
I am trying to set up a default U-value in a window schedule for a residential project. All windows are new. When setting the value (to .28 from “0”) in the property manager, the number keeps going back to 0. Is this a bug or is there some other, better way to set this up? The note under "value definition" in the property manager is confusing. Is it telling me that one or more windows already have the u value set locally and therefore will not allow a default value to be set? I just selected all windows and set the u value to "default" thinking I would then set the desired default value in the property manager. Isn't that how it's supposed to work???
Operating system used: Mac Apple Silicon '14 Sonoma
Robert Wilkanowski
Archicad 29
Mac OS '15 Sequoia
Hardware: M4 Max with 16-core CPU, 32-core GPU, 40 core GPU, 16-core Neural Engine, 64GB unified memory
1TB SSD storage
3 Replies 3
scottjm
Mentor
Is this in a teamwork file?
Some settings of properties can't be changed once the project is shared to teamwork.  You either have to remove from teamwork, change the setting and then reshare, or re-creat the property as a new property.
What Data Type do you have the property set as?
RWARCHPC
No, this is not a teamwork project. The data type is set to "number."
Robert Wilkanowski
Archicad 29
Mac OS '15 Sequoia
1TB SSD storage
In the Settings Dialog, did you just select the "Custom (Value)" option and entered a value?
And then it reverted to the default?
