exporting to autocad and dimensions problem
Hi all,
I am trying to save my project as a dwg file. I can save the floor plans one by one correctly. Then i want to merge them in a file.
When i do this i can't use ctrl+c and ctrl+v (copy/paste) command because of the same block name in plans. Then i use the "insert>external reference" command to place the drawings in autocad. i am using "bind" command to completely merge these drawings in the same file. Everything is okey until this step. Then when i want to change something on this drawing i have to explode each floor plan. When i explode it, all dimensions' extension lines getting bigger and dimension styles changes then reading the plan is getting very difficult.
How can i merge them by without problem.?
I save the plans from layout but it doesn't export floor plans' layers. It is only transferring layout's layers.
You know we must distribute the projects to other engineering disciplines. It is a big problem for me and others.
2 Replies 2
after
Petros Ioannou
Hi ogabson,
have you tried to change the extension line of the Dimension style that Autocad uses? Its a simple procedure but it must be done inside Autocad.
Petros
ArchiCAD 22 4023 UKI FULL,
Archicad 21 6013 UKI FULL, ArchiCAD 20 8005 UKI FULL
iMac Retina 5K, 27-inch, 2017
4.2 GHz Intel Core i7
32 GB 2400 MHz DDR4
Radeon Pro 580 8192 MB
