getting dxf import to show in
Hi folks!
I can import a dxf file into archicad, and the mesh shows in the floor
plan, but not in 3d window. Is there a way to rebuild mesh objects
into solids to that they display in 3d? Thanks in advance.
2 Replies 2
David Larrew
You will need to bring-in the 3D elements (mesh) as an Object.
David Larrew, AIA, GDLA, GSRC
a r c h i S O L U T I O N S
WIN7-10/ OSX 10.15.7
AC 5.1-25 USA
Djordje
Did you read the Help?
When you do, see also http://www.graphisoft.com/archiguide_archive/ArchiGuide_Online_6o/issue20/3ddxfimport.html Old but gold.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
