ā2008-05-02
07:53 PM
ā2023-05-26
09:03 AM
Rubia Torres
ā2008-05-02 08:34 PM
ā2008-05-03 04:42 AM
tigger wrote:In the site file, select the hotlinked building story and ('Suspend Groups' unchecked) elevate it in the floor plan, section or 3D window to its correct height. You select the insertion story based on what you want to see on the same story in the site plans, and then you can elevate up and down as you please.
I'm not so much concerned with how it looks in plan. Its my 3D views I need to be correct.
ā2008-05-07 11:57 PM
Ignacio wrote:If you do the above and have the group active, select the story and go to File>External Content>Hotlink Module Settings and set the required elevation relative to your site file.
