how to migrate 21 office template to 22
We have finally got an office template up and running that is working well for us, which was assembled in AC21. Now how do we migrate that template to AC 22. I would prefer not to do everything from scratch again. Is there a way of migrating to the next version without missing out on things or stuffing things up? Is there a list of new things to add/check when going from 21 to 20?
Any help appreciated.
There is a whole section on migration in the reference guide that explains it all very clearly.
The only thing it doesn't mention is the Work Environment.
If you have customised your WE, then you will either have to use new default WE and add your customisation in, or use your old WE and add all of the new features in to that.
And of course you will have to start setting up new features such as modifiers in complex profiles and expressions in properties if you want to use them.
furtonb
In my opinion it is a better approach to always start subtractive rather than trying to add the missing options - the latter requires thorough knowledge of the new Menus and features. Once comfortable, the whole UI could be done from scratch.
odv.hu | actively using: AC27-29 INT/HUN - multiple builds | Rhino6-8 latest build | macOS @ apple silicon / win10 x64
