Project data & BIM
imported text size in Plotmaker
hi,
I have just started working with Plotmaker.
I did ok with importing my dwgs into the Layouts.
I see that text size for dimensions and text is large and out of scale.
I can see in the dwg information that text size is set to 78 but I do not know how to change this. (ps: in my ArchiCad dwg the dimension texts and text is in a correct -proportionally- scale.
Any information would be appreciated.
thanks in advance
Constantine
pps: Djorge, nice to 'see' you again.
1 REPLY 1
Djordje
grapsas wrote:
hi,
How is your text scaling? Was the view that you are importing set to the scale that it is in in PlotMaker? This sounds like a standard view saved at 1:100 that is at 1:500 in PlotMaker?
Post a screenshot.
Happy to see you again, Constantine!
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
