isolating layers
In Auto CAD there is a "layer isolate" command, is there something similar in ArchiCAD.
Thanks
5 Replies 5
What does it do?
You pick a layer you want isolated, and all other layers are turned off except for that layer. It would be for working or moving a specific group of things so you don't have to mess around with all the other layers.
The QuickLayers palette has a button that does this. Select an object, then click the button for "hide all other layers".
Hey thanks,
I was born and raised in Billings. How is your weather?
You're welcome.
So was my wife. 🙂 Weather wonderful - clear in the 70's, snow in the mountains.
