2013-06-28
09:45 PM
2023-05-26
03:21 PM
Rubia Torres
2013-07-08 05:03 PM
Barry wrote:yes on the updating, ive even used my default pln created a brand new aat. then save close (probably not necessary) and reopen. load the recently saved saved aat with no changes to any layers or combos that are all how i need them, then i overwrite the layers, then the combos. apply and close the att manager. and then i am stuck on custom layer combo. when i open the layers i can select the combos and i see the layer priorities flash with the correct number. then its back to a custom combo with all priorities set at one. i can update each layer combo and then they work. but the aat file just isnt working. but like i said the pln when used everything is peachythepsyntyst wrote:When you are changing the layer priority number are you also updating the layer combos as well?
try opening the default ac 17 template file. then open the layers and change one or two of them to have different priorities. then open the attribute manager and save the layers and layer combos in an .att file....
If not then the AAT file you are saving will have layer combos with the old priorities so you will just be re-importing the old settings.
2013-07-09 03:40 PM
2013-07-09 03:52 PM
MarkMoscrip wrote:Mark:
RE: hotfix 3013, I can only assume that since I have a WIBU key and not a codemeter key, the GS website for upgrades is still to this day (July 9, 2013) informing me that 3002 is up-to-date.
2013-07-13 03:35 PM
