layers in views
Could anybody help me with figuring out how to get a layer permanently invisible from a view. I have a site around my building that keeps turning on as I toggle from the plan and section view. thanks[/img]
3 Replies 3
If I understand you correctly and you are using quickviews you would turn the layer off with the view active and redefine that view.
Gerald Hoffman
“The simplification of anything is always sensational” GKC
Archicad 4.55 - 30-Latest USA
2024 M4 Max MacBook Pro-OS Tahoe (128GB (16 Core CPU + 40 Core GPU)
thank you...I knew it was something super simple
In my opinion every view should reference a layer combination and not a custom set of "on" layers. If you set it up this way there is no need to ever re-define the view. Update the referenced layer combination and all views that reference this layer combination will be updated. Just a good general practice.
