lparke
lost annotation within schedule
within interactive door/wdw schedules i added various annotations/dims within the cell. I've recently lost that information + the vertical formatting of the cells. I originally thought it may be a layer issue but that's not the case. It's as if the schedule regenerated itself to the original view prior to any modifications. The windows and doors have not been changed in some time about the only thing i remember doing is making changes to the marker settings (shape and size) using select wdw (or door) tool, ctrl-a, change settings within dialogue box. Would this cause the generation of a new schedule?
ArchiCAD v28 (since v11)
MacBook Pro M1 Max, 64GB
macOS Sequioa
13 Replies 13
yes, it happens across all the TEAMWORK projects in 20 (started 19) and if your schedule view changes its setting such as renovation, scale, layer combo.. it drops all the custom annotations.
grr,,,,
We confirmed that scheduled elements in hotlinked modules (at least in a teamwork project) lose their annotation consistently. This has been reported to our local reseller, who told they'll be in contact with Graphisoft about this.
Katalin Borszeki
Hi All, this is a known error. The problem is that when you make multiple Views of a single Schedule with different Renovation Statuses, in one case it will list certain windows, and in another case they might not have the "existing" status, so they do not exist in the schedule either. As a result, the annotations connected to them have nothing to connect to, and they go missing.
There is no easy fix to this phenomenon. The only workaround to avoid the mentioned issue is to make sure that you only have ONE single View saved of each schedule (if you need more than one, please duplicate the whole schedule, and save the new view from there). Best, k
Katalin Borszeki
Implementation Specialist
GRAPHISOFT
http://helpcenter.graphisoft.com - the ArchiCAD knowledge base
jameshart
Our annotation disappeared after making changes to the schedule scheme settings. For anyone who is interested, you can read more here: https://archicad-talk.graphisoft.com/viewtopic.php?f=26&t=62958
ArchiCAD 27 (5003 USA Full), M3 Max MacBook Pro, 96 GB RAM, MacOS 14.5
