go
lparke
since ‎2008-06-08
‎2026-09-19
User Statistics
  • 39 Posts
  • 0 Solutions
  • 0 Likes given
  • 10 Likes received
User activity
With the introduction of design options in v27, are there any known settings to adjust in the IFC Translators? We communicate with a MEP consultant that uses Revit. Their Revit crashes up opening our IFC's that originate in Archicad v27. Over the past few versions, we've twe...
Not sure where we downloaded the object, but the elevation view is reversed from the plan view. I don't know GDL, but guessing/hoping its an easy fix in the code somewhere. Can someone help? TIA
I'm reworking our template favorites for cabinets to incorporate new features of AC25. Perhaps I haven't found it but can you:1) show dashed lines indicated door swings and shelving behind the doors in 2d elevations2) at a two segment base cabinet, when I set the lower segme...
Looking for advice when bringing in a structural engineer's revit structural model as an IFC hotlink module. With myself never using Revit and my P/E never using Archicad. how do we go about understanding the translators? Although we got it worked out after a few tries, I'm ...
I've brought in a Revit Structural model via IFC as a hotlink module. After some back and forth translation issues between Revit reference planes vs Archicad Stories I think we have it. However, as a HLM I cannot adjust pen colors. I can do this with Graphic Overrides global...
