ā2009-10-20
11:50 PM
ā2023-05-30
12:48 PM
Rubia Torres
ā2009-10-21 12:02 AM
ā2009-10-21 07:49 AM
s2art wrote:What other items are you thinking of? I would contend using SYMBOLIC CUT and producing a single floor plan the way to go... Only where a floor is ON TOP OF another, should you go to another story. With the maximum Flr to Flr described here at 6'-8", there should be NO floor on top of another.
With the single storey method you can use a single FPCP and set the walls to Symbolic Cut, but there may well be other items that will not display as you want.
ā2009-10-21 08:23 AM
ā2009-10-21 08:53 AM
ā2009-10-21 09:29 PM
vfrontiers wrote:Was thinking slabs, beams, roofs etc. All should be controllable though. Depends how far apart the split levels are and individual item's display settings. Definitely the best way to go.s2art wrote:What other items are you thinking of? ...
