ā2012-08-06
11:13 PM
ā2023-05-30
12:42 PM
Rubia Torres
ā2012-08-06 11:47 PM
another Moderator
ā2012-08-07 12:48 AM
ā2012-08-07 02:47 AM
ā2012-08-07 03:05 AM
another Moderator
ā2012-08-07 03:59 AM
ā2012-08-07 03:14 PM
ā2012-08-07 03:43 PM
s2art wrote:I just figured this out earlier this year, it saves a ton of time and trouble. You can change layer & pen color of a bunch of elements all in one click.
This button...
ā2012-08-07 05:05 PM
Barry wrote:Barry, I do the same thing! Great trick.
Here is a little tip I like to use.
When changing the layers of many elements in a plan, turn off the target layer.
Then as you change the layer of the elements (either by just changing the layer in the info box or using the edit selection dialogue (which is much better for multiple element types)), you will see them disappear from the screen.
This way you can easily see if you have missed anything and you know for sure that the layer has changed.
Now just turn on the target layer to see all your elements again.
