opening lower version from archicad 14
i have archicad files, version 6.5. the problem i am facing right now is that i couldnt open them in archicad 14, the one and only version i have. is theres anywhere to open the version 6.5 files??
5 Replies 5
Get one of the "file converters" - http://www.graphisoft.com/support/archicad/downloads/Fileconverter.html
"" - because they are normal ac versions striped down and the instalation is not needed.
Best Regards,
Piotr
Thanks Piotr, will try downloading that.
cheers
i have downloaded the file and drop them in the Archicad 14 program folder.what do i need to do to make it work?i tried to open the 6.5 file after that and it still wont work.
oops...
Extract the folder and run archicad.exe (win) ora app (mac) from that folder
As I said - the converter packages are full ACs.
Best Regards,
Piotr
it works..thank you very much...
