‎2016-03-03 11:52 PM
‎2016-03-04 12:23 AM
‎2016-03-04 01:46 AM
‎2016-03-07 11:53 AM
sboydturner wrote:That is true only if you all have the same libraries and any custom objects are same in the Embedded Library (which means they are included in the PLN file).
All your users would typically need is the *.pln file.
Scott
‎2016-03-09 06:21 AM
‎2016-04-04 06:42 PM
luisarch wrote:Why would you do this? And I'm not even sure HOW you would do it reliably. Your library manager allows you to embed the used library parts with one click, and creating a .PLA file is also very quick. If this all is taking more than, say, one minute total, you probably are not doing it correctly.
Thank you for clarifying Lazlo,
I generally manually create a .pla which takes a bit of time .
‎2016-06-14 02:16 PM
Richard wrote:This is the real question.
