"BLOCK" - GDL - Hotlink ?
I am looking to create a basic 2d "block" (as autocad calls it)
I want to be able to edit the "block" once and all instances of this be updated through out the project.
i would prefer not to have this as an externally linked file.
what have you found to be the best method to accomplish this?
thanks!
2 Replies 2
Do it in GDL.
Draw the 2D on the Floor Plan, then save it as an Object. Then place the object.
Check the Help files for additional info and Detailed Steps.
When saving - since you did NOT want an externally linked file - be sure to use the default of saving into the embedded library (which is part of the project file itself).
AC 29 USA and earlier   •   hardware key   •   macOS Taho 26.5 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
