This forum is dedicated to BIMcloud SaaS Public Links - Early Access. Interested in joining? Click here for further details.
Friday
- last edited
Friday
Does anyone know why my Steel Shapes Library is no longer acting as it normally does? Currently, I cannot make a size selection, only 40x999, and all of the steel section objects I've placed read as "Size not found Try new values or see MSA Steel.pdf". I think this started around when I updated my AC28 Library through the updates dialog.
I feel like I need a PhD to manage Global Libraries, Legacy Libraries and Embedded Libraries. I have created wall sections that now have missing steel sections, and the aforementioned text. I spend so much time everytime I need to fix a Library issue, I can't do my real work.
Solved! Go to Solution.
8 hours ago
I ended up replacing the Archicad Legacy Library and it resolved my issue. Must have corrupted something at some point in that library.
Friday
Just realizing maybe this i snot the right place for this...apologies.
8 hours ago
