Setup & License forum
DWG
BryanRichards
As new as they come to Archicad v7.
Reverted for rendering qualities (hoping im making the right move as ive not much time to play about, but ive seen some examples)
What can you import from DWG files?
I currently use Architectural Desktop 3.3 and Revit but i need a program where i can construct a "solid" from Desktop and import it.
Can i import a 3D solid into archicad, i get error messages when i click File>Merge saying "Warning","undocumented entities found" ????
Any help from the archicad big dogs would be appreciated
22 REPLIES 22
BryanRichards
just to add,
ive tried the command Dimdisassociate then selecting the object.
3D walls import but im having a problem seeing those in 3D just plan. Really i need to import a solid
thanks again
Bryan
Ben Odonnell
Brian.
Unfortunately you can not import solids into ArchiCAD check out this link http://archicad-talk.graphisoft.com/viewtopic.php?t=319&highlight= for a nice tutorial on a great method for importing AutoCAD solids into ArchiCAD
Ben O'Donnell
Architect and CTO at BIMobject®
Get your BIM objects from bimobject.com
Ben Odonnell
Brian.
Ben O'Donnell
Kerry
Bryan,
to get a solid from a dwg or dxf file you need to open as a GDL object
IN AC7 go to
FILE then
OPEN LIBRARY PART
then change format to dwg or dxf,
once object is opened, save as and give the object a name,
the object tool should now be set to your object.
place it in the drawing.
this object will only have selection points on the corners and at the centre.
If you need points in specific places for accurate placement let us know and we can help there. ( thats if your not sure how to yourself )
Kerry Reyburn
AC8, PM3 G5 1.8, 1.5 ram
BryanRichards
Thanks Ben and Kerry, im getting there thanks to this site.. Ive imported a simple solid cone into AC7, well converting it into surfaces first. I see the plan of the cone in Archicad (MUCH bigger than expected. Why has the scale increased? ) but when i (shift+3) its not there?/??
is there something i have to set in the 3d window? if your working within archicad the 3d window focus's on whatever you have selected..
thanks again
Kerry
Bryan,
Maybe you need to explain the steps you go through to import the cone so we can see how and where you may need to do things different.
Kerry Reyburn
BryanRichards
The steps im taking
-Cone made as solid in Architectural Desktop 3.3
-Comand 3dsout is made and solid selected
-Command 3dsin is made, the new cone file is imported to cad
-The cone is now made of surfaces and saved as a .dwg
Thats fine (now my favourite bit)
-in AC7, i file>open>cone.dwg
-a window appears where i "open as and archicad project"
-I select explode (not sure of the differences yet)
-Translate the .dwg drawing unit into 1.00
-I leave expert as im clearly not hehe
-Click ok
-There it is in plan mode
-You then asked me to save this cone
-Save as .pln
-I then close this, reopen my existing file. Ive made a wall 8metres accross
-I then merge the new cone.pln
-i paste in current view + zoom to pasted elements
-The wall is there and the plan of the Cone
- just when i thought id done it i pressed Ctrl+3 for the 3D view. The wall is there but the cone is not.. I need to be able to render this in the end
Thanks once again
Kerry
Bryan,
Once you have the cone solid saved as .dwg file
then open your Archicad file. don't open the .dwg as a new project.
You need to be in archicad first then follow the next few steps:
1. start with a blank Archicad file open
2. go to file menu, click on open Library part.
3. this will bring up a dialog box for you to search for your .dwg file. ( the default library part format is .gsm so you may need to choose .dwg from the file format list.)
4. once you have found your file click open
5. a dialog box for the file translation will apear, you need to select create library parts not the grouped or explode options.
6. this will bring up the GDL editing window and your object.
7. now save this as a .gsm object
8. from archicad select the object tool and click on the plan area. this should place the cone.
P.S. I may have missed something in my explanation, so If your not in a hurry I will work through the steps myself to confirm, but can't do until latter today.
once yourv'e done it a couple of times it's easy.
But the cone needs to be an object. opening a .dwg as a .pln file will not have any 3d model.
Kerry Reyburn
BryanRichards
Check you out! working now.. I hope i get to grips with the rest of the program a bit faster than the hours invested into that one...
but guess what hehe one more prob.. when i few it in 3d parallel mode its there, when i hit perspective its gone ..?? somewhere.. cant seam to move about to find it either..
this program is laughing at me now
Kerry
Bryan,
from the floor plan zoom out a bit from the cone position.
then from the image menu open the 3D projection settings.
hold the alt key or option on mac and click in the plan window of the perspective settings window.
then do the same with the shift key pressed.
you should now see the view cone. check the heights of the camera and target in the boxes beside the plan view window then press o.k. and go to the 3d window.
it's just a matter of getting the camera to look at the cone!
I use to have the same problems and now and then still do.
Kerry Reyburn
BryanRichards
thanks very much, youve been a great help. working through the night once again if there are any other student architects out there, your not alone!!
Djordje
Bryan,
Why import a cone? The one in your standard library does a much better job - it is parametric, it has few KB, and it is native.
IMHO you should revise your working methods with an experienced ArchiCAD user - solids are NOT the only way, however you are used to them. And, for the solid ops you are used to, you need at least ArchiCAD 8.
Good luck, and I am glad the list is providing you valuable info
Djordje
ArchiCAD since 4.55 ... 1995
BryanRichards
hm thanks was using the cone as an example primarily to import a solid from desktop. What im going to do now i know i can is create a 3d draping thin canvas, sloping in 3 directions to cover a part of my building. I know revit cannot do this, im only guessing archicad cannot do this, so my solution was to import a solid from architectural desktop.
One niggling thing i have with archicad is the maneuverability. Is there a fast way to pan and to zoom or do i have to keep selecting the option with the mouse? I like to work with the keyboard and mouse at the same time, its faster.. ?
Ben Odonnell
Brian.
In ArchiCAD, from ArchiCAD 8 and onwards, you are able to pan and zoom with your mouse. May be an upgrade is on the cards? .
This is not the only reason why you should upgrade, there are just too many to mention. Check out Djordje's post here. http://archicad-talk.graphisoft.com/viewtopic.php?p=2238#2238
It will point you in the right direction and will answer any questions you may have about the latest version of ArchiCAD.
Cheers.
Ben
Ben O'Donnell
__archiben
bryan
if you have a scroll-wheel-with-button mouse you can pan and zoom using the scroll wheel -
by default, my setup is;
• scrolling the scroll wheel: zooms in and out
• clicking the scroll wheel button and dragging: pans
~/archiben
b e n f r o s t
Ben Odonnell
He is using ArchiCAD 7.0
Ben O'Donnell
Jay Garbarino
BryanRichards wrote:
.. Is there a fast way to pan and to zoom or do i have to keep selecting the option with the mouse? I like to work with the keyboard and mouse at the same time, its faster.. ?
Bryan, In AC7 click on the Display Pulldown and you will see a list of the zoom commands with their associative keyboard commands. (ie. On PC, "Zoom In" is the Ctrl key with the " / " key And the "Fit to Window" (Zoom all) is the Ctrl key with the " ' " key.)
Hope that helps (HTH)
Jay A. Garbarino - Cornerstone Engineering
Windows 10 Pro
Dell XPS 8930 - 3.20GHz Intel Core i7-8700- 32GB RAM - 6GB NVIDIA GeForce GTX 1060
Dual Monitors
AC23 USA Full
BryanRichards
ahh, that works for me
Wish there were two control buttons on a lap top but now im just being fussy thanks
symm
I think I hear GDL Toolbox promo coming...
