2022-12-13 01:21 AM
Is anyone else seeing hard crashes upon selecting the Page Setup menu item on M1 chip? I'm running current v26 on Mac Studio with macOS 13.0.1.
Bug report is submitted. It's nasty!
Solved! Go to Solution.
2022-12-13 07:42 AM
I haven’t noticed this. Could it be that the print driver needs updating?
2022-12-16 01:22 AM
Something like that, Lee. In any event it's fixed now. More likely related to printer rather than Archicad or macOS. Thanks for responding.
2022-12-16 02:13 AM
Robert, how did you fix the issue? Just got a mac studio and can't get v26 to launch at all (keeps crashing)
2022-12-16 04:24 AM
Hi, Arqtect.
I fixed my situation by downloading a fresh printer driver from Brother, but it sounds like you are having a different, more fundamental, problem. I would ask if you are sure you have the Apple Silicon version of v26 on your Mac Studio, but I doubt the installer would have worked if there was a problem with that. If the crash is immediate upon starting Archicad, I would suspect something to do with the licensing components.
Go here: https://Graphisoft.com/downloads/protection_key and download and reinstall the Codemeter driver. Someone else helped me find that last week, and it worked.
2022-12-16 04:03 PM
Thanks, I will give that a try. I will likely end up contacting Graphisoft support for help
2022-12-21 06:59 PM
I get the same crash when selecting Page Setup in Archicad 24 on a 2019 MacBookPro (intel). I've updated to Ventura 13.1.
2022-12-21 07:16 PM
At first I let the OS prepare my printer setup (new computer, so much to set up). That's when I got the crash. Following advice of someone here, I went to Brother (printer manuf) site and downloaded a printer driver from there (which happened to be AirPrint in this case - I guess proper networked driver for Ventura not ready yet) and the crash went away.
2023-01-16 11:29 PM
I'm having the same problem, but only with one file. Page setup causes a crash in all views.
2023-01-16 11:35 PM
Interesting. All files make it crash for you? In my case, it's not all files. I'm on a newly acquired and set up machine, and I suspect files that had one particular setting on the old machine are choking the new. At least that's the impression I have (actually have no useful knowledge about the insides of computers).
Thanks for weighing in. Hope your situation improves. I sent Graphisoft all the diagnostic info they requested, so hopefully something will happen.
