Showing results forĀ
Search instead forĀ
Did you mean:Ā
Search instead forĀ
Did you mean:Ā
Installation & update
Making the switch
I'm getting ready to upgrade from AC11 to AC13 and I've seen the post about Snow Leopard and AC13.
I was wondering if there is anything else I should be aware of or any other useful tips you can give me about migrating older files, favorites, work environments, etc. This will be the first time I've ever upgraded.
Thanks.
1 REPLY 1
hi,
I've upgraded from 12 to 13. There is no issue. You need to have migrating library 13 from 11.
Apart from that, most of your favourite created in 11 (w 11 Library) need to be redo with 13 Library, if you dont wanna load Migrating Library forever.
It's worth a change.
