Installation & update
MultiLanguageUserInterface??
Ustunes
I've worked on with Archicad on difference platforms. First one is based on Archicad native language users. I work with them with native language user interface. Second one is english template with global workflow. How can i deal with this situation on my only one computer?  I dont know whether I should install Archicad with different language templates on my compture or not. Is there any option in Archicad like other softwares/apps to change  interface language regularly&smoothly instead of instaling one more time on your desktop?
1 REPLY 1
There is no way to change languages in Archicad.
You need to install separate language version if you want the program itself in those languages.
But your license may be limited to the language versions it can run.
The files of course you can use in any language version, you just type in the language you want it to be.
Learn and get certified!
