Well, I actually believe that solid state drive can actually give a boost. Of course this is an assumption, this is why I am asking about someone's real life experience.
For example, my notebook has tended to slow down as there were more and more programs installed. With a solid state drive, the whole operating system gets a boost, so all programs start up faster.
A friend of mine saw a video of a op. system booting from a solid state drive. XP was up and running in about 8-10 seconds!!! That's not bad, if true.
Also, I can imagine that this can be important when working with large projects that require more than the available physical memory (e.g. more than 2GB under XP). In that case the swap file comes into play, which, if stored on a solid state drive, can make the whole operation much faster.
Let me know what you think, guys.
