Sustainable design
About EcoDesigner, Energy Evaluation, Life Cycle Assessment, etc.
About climate information format?
What is the TMY files (*. Csv)?
Because Automatic download of climate information is incorrect,
I want to use this format input climate information, thanks.
5 REPLIES 5
Correct Wind roses chart
Hello
You have probably solved this problem, but TMY files can be easily generated with Meteonorm software. It a database with climate data all over the world. TMY3 files are in csv format and can be easily edited in Excel. I'm now trying to contact developers of EcoDesigner Star to find out what kind of wetaher data is required for EcoDesigner Star. That information can help to customize weather file in Excel.
Dear aleksey51,
" I'm now trying to contact developers of EcoDesigner Star to find out what kind of wetaher data is required for EcoDesigner Star. That information can help to customize weather file in Excel."
Great!
Because Taipei is a basin topography,
I think sometimes the climate affected by topography, wind direction will change.
Thanks for your help.
I found the taipei.tm2, please refer to the attached file.
It can work properly, the problem has been resolved.
Correct Wind roses chart Generated by ENERGY EVALUATION IN ARCHICAD 17.
