2020-01-08 02:21 PM - last edited on 2023-05-11 10:26 AM by Noemi Balogh
2020-01-08 03:29 PM
2020-01-08 03:37 PM
2020-02-07 09:19 AM
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
2020-02-08 02:30 PM
JamesLEDA2 wrote:
firstly, please don't banish this threat to the Sustainable Architecture section to be ignored with the tumbleweeds.
2020-02-09 07:54 AM
2020-04-25 08:27 PM
JamesLEDA2 wrote:Hi James, did you solve your issue? I'm also interested in the exportation workflow from Archidad to PHPP, If yes would you be so kind to share your experience?
IMO, this is more a technical issue than a request for help with sustainable architecture. This part of the forum is infrequently visited hence my request. But you are right and I will be following up with GS HQ.
2020-04-25 08:35 PM
2020-04-25 09:23 PM
stetuv wrote:Hi,
Minh Nguyen
GRAPHISOFT
2020-04-25 09:32 PM
No, Graphisoft requested I send them a model, however this is unnecessary as you can build a simple 10mx10mx10m cube with walls and a flat roof and a door in the north (1mx2m) and a window (1mx1m) in the south and see that the export to PHPP is incorrect.
It outputs odd areas that don't correspond to what they should be and what would be entered into the PHPP if it was being manually measured by a Passivhaus Designer (or anyone knowledgable about PH)
Minh Nguyen
GRAPHISOFT
