2020-01-08
02:21 PM
2023-05-11
10:26 AM
Noemi Balogh
2020-09-23 09:21 PM
2020-10-02 02:18 PM
andyro wrote:Andy, I completely agree that it would reduce a lot of input (not 90% however, there is significant input required regarding the shading and heating, I've not checked U-Value and thermal conductivities of elements) however, one of the main reasons that PH is a safer standard is because it uses external dimensions, thus over estimating the heat loss. then, by calculating areas externally, the thermal bridge PSI values tend to be negative, which is essentially a correction factor for overlapping elements.
While I can't speak for Graphisoft, the detailed consideration for vertical (by structure) thermal bridges and lateral (psi) thermal bridge simulation and addition of length parameters (you model every lateral detail, and provide a length multiplier in the structures list view), as well as window installation psi values, appears that EcoDesigner's developers were in fact aiming to align 100% with PHPP. In fact I wrote a blog on this here:https://www.thomsonarchitecture.ca/2020/08/15/archicad-ecodesigner-and-passive-house/
I have yet to complete my PHPP course of study and exam, but it seems GS is 90% of the way towards a completed tool. The PHPP export works (tested to 9.6) but is partial, and Exterior Envelope Area needs to be calculated in 2 ways, for its own calculation methods, but also for PHPP export. This could considerably reduce the PHPP input process if export was consistent and reliable, not to mention well documented.
2020-10-02 02:39 PM
2020-10-02 03:48 PM
2023-03-01 01:08 PM
I have some information that can explain these area discrepancies. But there are parties interested in updating the PHPP export, mapping to the new PHPP. Feel free to write me at [email protected]
2023-03-01 01:14 PM
Afaik Minh the exterior faces are considered, but the interior surfaces are projected, so the corners are missed, that is the difference between the Evaluation Report's 'Gross Floor Area' and 'Treated Floor Area'. The portions of Window footprints are also subtracted. This is not really a matter of right and wrong, what is needed is a fresh approach to EcoDesigner surface mapping design and export tools. Filling in the gaps is not a Herculean effort. Many more people are trying to do this and failing - those human-hours could be better spent refining the tools at GSHQ 🙂
2023-03-01 01:18 PM - edited 2023-03-01 01:19 PM
PS - both PHI and GS are 'wrong'. Heatloss actually starts at the interior surface air film, and ends at the exterior surface air film, if a 'building' is considered as the system boundary. The heatflow calculations should consider the interior area, but the corner conditions should be mapped in a radial manner - neither GS or PHI have bothered to do that so the PH answer is apply heatloss from the exterior surface using an aggregated U value with all psi and chi values applied. Please correct me if I'm wrong, which is 50% of the time easily.
2023-12-19 01:47 PM
I had a detailed meeting with GS UK to try and understand what they are doing to update and align the Eco Designer Star with PHPP, and there is insufficient interest with their users for this event to make it on the long-term roadmap.
We are currently refining ours but given the lack of interest within GS (from 2013-2023 to align the tool with PHPP), the increased cost of AC (now comparable to Revit) and the prevalence of better tools for automation of PHPP input in it, I am wondering whether it is time to cut and run.
I don't buy the argument that there isn't enough interest: It is a global imperative to design more sustainably, and providing the tools before they are demanded is, seemingly a business-savvy approach.
I would love to hear more about your AC to PHPP workflow. if any of you are open to chatting about strategies.
2023-12-19 02:10 PM
I don't buy it either. One can assess demand and one can create it. I doubt either has been attempted apart from casual/anecdotal remarks. The thing is, this is ripe for a user-base intervention. With AI now, you could probably pretty handily map parameters between the ED/EE output and the latest version of PHPP via the xml file that resides in the add on/energy evaluation/localization country folder. Agility is required to develop solutions. There is a global demand for this, I've seen it in almost every country I've visited or have colleague/friends in.
2023-12-19 10:33 PM - edited 2023-12-19 10:36 PM
Interesting to see this section of the forum resurrected from time to time, whereas the built environment still contributes to global warming with each passing hour, so I don't really get that there is no demand. It would be a moral imperative to develop tools to assess embodied impact (AFAIK a tool is in progress to link bMats to Ökobaudat and have a reliable life cycle assessment available within Archicad for earlier life cycle stages), but Archicad is still cut off from the existing thriving ecosystems and bleeding heavily.
If you haven't checked, there is a tool being developed by Ed May (company: bldgtyp.com, Honeybee2PH, which lets you export HB models to PHPP:
https://ph-tools.github.io/honeybee_grasshopper_ph/
The interesting stuff, that Honeybee models can be generated with Pollination directly from Revit (enabling rapid AND VALID model export not only to PHPP, but EnergyPlus, IESVE, IDA ICE, you name it).
With costs being increasing noticably on an annual basis, I would expect Archicad to open up and integrate into the BEM world as tightly as Revit does, but at the moment the current gbXML-based workflow is so time consuming and erroneous, that my choice is to remodel because it is way faster than the endless troubleshooting.
I get, that there seems to be low demand, but there seems no point trying (I am happy to be proven otherwise).
If Psi values were taken into the conversation: does anyone know, how they are calculated? Is ISO 10211 or another, similarly applicable standard taken into consideration? How accurate is the calculation of Ecodesigner STAR's thermal bridge module? Maybe this should be its own thread...
