Sustainable design
About EcoDesigner, Energy Evaluation, Life Cycle Assessment, etc.
ECODESIGNER STAR
chrrev
Could GS advise on the current status of ECODESIGNER STAR.
One gets the distinct impression that it is a dead end project since there are no serious answers from GS to real problems.
I am involved with clients who request zero energy buildings and I have been under the illusion perhaps that EDS could deliver...
Please advise , then we could summarize the outstanding problems if the project isn’t dead...
Either way , we need to know please.
This isn’t a field where we can rely on vague approximations and contradictory results.
18 REPLIES 18
I could not agree more. The stagnation of Ecodesigner Star is a missed opportunity. We have lost faith in Ecodesigner Star as we often have inaccuracies during the calculation phase and some of the assumptions built into the analysis are flawed.
We are now purchasing Sketchup to enable a relatively quick 3D model PHPP Passivhaus assessment using the Passivhaus designPH add on. Such a shame that Ecodesigner Star can't export successfully to PHPP. We have tried and it is just too unreliable. I would much rather use ArchiCAD for all our BEM modelling but PHPP has overtaken us!
Any chance of getting a refund on a perpetual licence, so we can subsidise our purchase of Sketchup?!
DGSketcher
Legend
Given NEMETSCHEK / GS are trying to take on the whole of the construction design industry I share the view that EcoDesigner is a missed opportunity. From an Architectural perspective an industry standard (PHPP) working energy analysis tool would be a real benefit to promoting AC to Architects, especially if it was useable.
Aaron Bourgoin
PassiveHaus notwithstanding, there are plenty of other reasons to want to have access to a tool like this that works. Integrated design depends on it and local codes mandate the use of Energy models.
Think Like a Spec Writer
AC4.55 through 29 / USA AC28 USA
Rhino 8 Mac
MacOS Tahoe 26.0
Minh Nguyen
Graphisoft Alumni
Graphisoft Alumni
Dear All,
Thank you very much for sharing your opinions, and I can totally understand your frustration toward EcoDesigner!
For the next major release, EcoDesigner is not being updated, but we constantly fix bugs when reported to us. As of now, we are still collecting clients' requests in order to have a clear vision of how we can improve its function and how we can adapt better to the market.
Thank you for your understanding! I truly hope that, EcoDesigner can and will become a tool that will enhance architects' workflow around the world for a better future!
Have a great day!
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
A do also have impression of:
- Ecodesigner being way to much not reliable. Last test I've made gave me results more than 4x lower of energy demand than should be
- Ecodesigner cant export gbXML which would be compatibile with other BEM software - (interior walls as seperate is the main problem)
- no new recent updates of Ecodesigner gives a impression it's dieing
- lack of valuable information on how to use it to get fast and reliable results ( sample projects, tutorials, webinars etc) makes it difficult to find the proper workflow.
On the other hand it seems to be sooooo close to be a really outstanding tool allowing architects to design better buildings due to its integration with AC and some sort ot easyness of use. It seems to be a tool that needs just a few improvements and a better documentation to rock.
Please update the gbXML export without waiting for any AC updates (do it as a hotfix).
Or remove this export option and stop saying that AC can export gbXML since those files in fact cant be used to make a real energy evaluation in other BEM software (like OpenStudio), or prove they can be used.
Jp1138
That´s the impression I got too. I haven´t even tried to learn Ecodesigner as it seems to me is unreliable and mostly dead - only from what I have read around, because as I say I haven´t used it If this isn´t the case it a very serious communication problem on part of Graphisoft.
ARCHICAD 29 SPA (as long as the server works)
Windows 10
Minh Nguyen
Graphisoft Alumni
Graphisoft Alumni
Hi Philips,
Thank you for sharing your opinion regarding this topic!
I must admit, EcoDesigner is a sophisticated tool requiring accurate handling in order to achieve good results. We made some articles and instruction videos can be found in our Help Center from the links below:
https://helpcenter.graphisoft.com/knowledgebase/127368/
https://helpcenter.graphisoft.com/user-guide/77214/
But, it is indeed a difficult tool to master, therefore more tutorials are absolutely needed!
Regarding the gbXML export, unfortunately I'm not an expert on this topic. But I would like to address that EcoDesigner can export the model to gbXML. Here is the article about gbXML with Energy Evaluation: https://helpcenter.graphisoft.com/user-guide/89250/
If you find any issues arise from using EcoDesigner, feel free to report it here or via the local partner!
Thank you very much for your enthusiasm and attention to the tool!
Have a great day!
Best regards,
Minh
Minh Nguyen
GRAPHISOFT
Andy Thomson
Minh, there are no videos that I can see, as you suggest. I have had good results, after 22 successive model runs, and can attest that this is not a 'pushbutton' solution for BIM/BEM - it does requires some pretty deep BEM knowledge to understand what needs to be tweaked to give accurate results. That said, it would be EASY for GS to pre-program a few templates with standardized results for small and larger buildings to facilitate the workflow. I am working on this right now with our reseller for Canada - with a few simple tweaks I think we can use this for OBC/SB12 code compliance 'performance path' modelling and I have already received clarification from our provincial ministry that this will be accepted as the VIP modelling core provides hourly analysis. I will be posting a blog on this soon.
Andy Thomson, M.Arch, OAA, MRAIC
Director
Thomson Architecture, Inc.
Instructor/Lecturer, Toronto Metropolitan University Faculty of Engineering & Architectural Science
AC26/iMacPro/MPB Silicon M2Pro
Aaron Bourgoin
Yes!! Thanks Andy, I'm looking forward to seeing what you come up with.
Rhino 8 Mac
MacOS Tahoe 26.0
