PS - the interesting thing about Passive House, is that not only is it the only energy standard that uses the same evaluation methodology and objective energy targets everywhere in the world as certified by PHI, but that the extensive localization work usually required to meet regional codes can be bypassed if PH standards are met. For example, at the higher levels of the BC Energy Step Code or the Toronto Green Standard here in Canada, PHPP results and PHI compliance/certification is accepted by our building codes on an equivalency basis - provided one does the reference modelling. That said, EcoDesigner STAR is capable of generating 90% of the data needed for PHPP data completion, AND it can automate comparison with a reference model as per ASHRAE 140 protocols. So LEED/PHI/Code compliance is possible with a single tool - ArchiCad! It just needs some guidance to complete the process and add a few wee tweaks for data export.
Andy Thomson, M.Arch, OAA, MRAICDirector
Thomson Architecture, Inc.Instructor/Lecturer, Toronto Metropolitan University Faculty of Engineering & Architectural Science
AC26/iMacPro/MPB Silicon M2Pro
