Loading IWC File
I have downloaded the weather data in .IWC format, from http://www.nrel.gov.
How can I load this to ArchiCAD?
I thought this data are compatible with IWEC, but apparently IWEC has .STAT and .EPW format
3 Replies 3
Now I have various type of weather data, but not one of them is VALID to EcoDesigner. What's happen?
Works like a charm.
Hope screenshot below helps you.
Hi Kevin,
Thanks. Finally someone replied this.
I have done exactly what you showed, but it said INVALID Weather data.
Would you mind to examine the weather file?
Please PM me, and I will send you the file.
Thank you in advance.
