kajnorberg
Part of slab marked as exterior in EcoDesigner?
Hi!
I'm struggling with EcoDesigner. I've made zones that I've connected to thermal zones. The problem I'm having is that parts of the slab between the stories for some reason are marked as exterior. The parts are those that have interior walls below or above, and I can't figure out how to fix this.
Any ideas?
Kind regards
Kaj
Archicad 24-26 SWE
Dell Precision 5560
Windows 11 Pro
1 Solution
Minh Nguyen
Graphisoft Alumni
Graphisoft Alumni
Dear Kaj,
Thank you very much for the question!
It is hard to tell from the screenshot, but I assume that above the interior walls there are zones? If that's the case, when above/below a zone, if there is no zone (in this case the interior walls take the space), EcoDesigner marks it as exterior. But this "exterior part" is negligible for the entire building.
Please let me know if it answers your question!
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
Go to post
2 Replies 2
Minh Nguyen
Graphisoft Alumni
Graphisoft Alumni
Dear Kaj,
Best regards,
Minh
Minh Nguyen
GRAPHISOFT
kajnorberg
Hi Minh!
Sorry for not replying, just slipped my mind! That was exactly the case, thanks for your answer!
Kaj
Archicad 24-26 SWE
Dell Precision 5560
Windows 11 Pro
