2009-04-28
04:14 PM
2023-05-11
10:25 AM
Noemi Balogh
2009-06-11 02:04 AM
2009-06-11 06:38 AM
2009-06-11 09:04 AM
2009-06-11 11:24 AM
constantine wrote:I have had the following reply from my reseller regards Ecodesigner.
I am confused between EcoDesigner, Archiphysik and Ecotect.
Does anybody have any suggestion regarding their comparative appropriateness in getting the basic energy consumption info and producing the energy certificates required by building legislation?
thanks in advance
2009-06-11 12:44 PM
2009-06-15 05:50 AM
Mats wrote:Mats,
Hi again!
StruSoft-BESTEST
When the conditions starts to be close to passive buildings with thick insulations, different kind of heat recovery systems, solar panels and technical equipment like heat pumps then it gets impossible to calculate energy consumption with any level of accuracy with static methods. StruSoft-BESTEST is a validation method for this circumstances inspired by HVAC-BESTEST and developed by StruSoft AB to determine a software's ability to handle infiltration, heat recovery from ventilation units, sewer, solar panels, different heat pumps, special condition in the north part of the northern hemisphere and conditions north of the arctic circle where the suns shine 24 hours a day in the summer and it is dark in the winter. StruSoft-BESTEST was developed because other international test methods did not cover infiltration, heat recovery and Nordic conditions adequately.
To qualify for these tests the software have to be dynamic.
Mats Ola
2009-06-15 09:40 AM
2009-06-15 10:04 AM
2009-06-15 01:57 PM
2009-06-15 03:05 PM
Mats wrote:I think a discussion about gbXML really belongs somewhere else - it doesn't have much bearing on ED. Having cast doubt on gbXML as a transport mechanism, however, I think it's only fair that you provide some solid facts. gbXML was designed specifically to transport building data for green analysis and design; from gbXML.org:
In the same way gbXML is not built for and can't handle this kind of buildings. If you look at the gbXML specification today it might work for dimensioning hvac and mep equipment like heaters, radiators, coolers, boilers, ventilations units etc.
We know that the gbXML spec is not working for energy calculation under normal Scandinavian circumstances and with solution that build on natural ventilation and cooling. We also know that the specs seems to work under"normal USA conditions" thin insulations and when you control room temperature with heaters and coolers. But somewhere along the line gbXML stops to work as a information (data) transport solution.
gbXML.org wrote:The building fabric, context, and usage is described in enormous detail, including individual room volumes, detailed construction data (layers of materials including doors/windows, engineering data/characteristics, adjacencies), room usage (people and equipment), building occupancy patterns, shading, lighting, plant, etc.
The Green Building XML schema, referred to as “gbXML”, was developed to facilitate the transfer of building information stored in CAD building information models, enabling integrated interoperability between building design models and a wide variety of engineering analysis tools and models available today
