Sustainable design
About EcoDesigner, Energy Evaluation, Life Cycle Assessment, etc.
materials - thermal conductivity values.
In the process of assigning thermal conductivity values (BTU-ft/hr.ft2.F) to building materials.
Its seems to automatically round to 2 decimal places. That makes the values for rigid insulation and fibreglass batts at the same value! Any ideas?
David Maudlin
Adam:
It looks like the number of displayed decimal places is controlled by Preferences > Working Units > Angle & Font Size Decimals in Dialog Boxes (for the Physical Properties in the Building Material dialog box).
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
AC29 USA Perpetual • Mac mini M4 Pro OSX15 | 64 gb ram • MacBook Pro M3 Pro | 36 gb ram OSX14
Thats it. Thanks very much!
A
Aaron Bourgoin
maybe the ArchiCAD template file and default work environment should be set to a higher number of places to start. Seems odd that 1/64 is the default for working units, but other values are set less fine.
Think Like a Spec Writer
MacBook M4Pro
AC4.55 through 29 / AC29.0.2 USA
Rhino 8.26 Mac
MacOS Tahoe 26.2
