Teamwork & BIMcloud
ArchiCAD BIMServer 21 - Project Access settings
fuzzytnth3
In ArchiCAD 20 we have a Project set up so only specific users with a particular Role could access the Structures Model.
However in ArchiCAD 21 I have set up the same thing but users who do not have that Role are still able to edit the Model whereas in AC20 they couldn't.
Is this a glitch in ArchiCAD 21 BIMServer?
The screenshot below shows the Access settings
AC versions 3.41 to 25 (UKI Full 5005).
Using AC25 5005 UKI FULL
Mac OSX 10.15.7 (19G2021) Mac Pro-2013 32gbRam AMD FirePro D500 3072 MB graphics
6 REPLIES 6
Istvan Moharos
Graphisoft Alumni
Graphisoft Alumni
The two versions are the same in case of the permission system.
I suspect that those users who can access the project probably has got a management role (project or server administrator). Note that users who have management roles get full access to the whole project tree. Could you please check this?
Regards,
Istvan
István Moharos
Manager, Technical Services
GRAPHISOFT
fuzzytnth3
The users who should not be able to access it their Role is set to Lead Architect and their Management Role is "not set"
Istvan Moharos
Graphisoft Alumni
Graphisoft Alumni
And could you please verify that the Everyone usergroup with Member's defaults entry is also removed from the affected project's Access settings?
István Moharos
GRAPHISOFT
fuzzytnth3
Yes I had deleted that Role so the only Role available is the CG3-Structures one
fuzzytnth3
Apologies all.
It seems I was a numpty and should have double checked. There seems to have been a delay between me changing the settings on the BIMServer and what the User was able to do. We discovered today that the changes I had done to the BIMServer had in fact worked.
So nothing to see here, move on....
We have all been there...
