2011-03-29 05:38 PM
2011-03-29 07:04 PM
2011-03-29 07:42 PM
2011-03-29 07:52 PM
2011-03-29 11:07 PM
2011-03-29 11:08 PM
2011-03-30 12:20 AM
Page wrote:
Note: One component of the Graphisoft BIM Server is the BIM Server Manager, which is installed automatically along with the BIM Server. However, you can also optionally install the BIM Server Manager as a stand-alone application on remote machines. Separate, stand-alone installation of the BIM Server Manager (available from the Tools & Utilities section of the ArchiCAD 13 installation DVD) is necessary only if you plan to manage the BIM Server remotely, from a machine other than the server itself.
2011-03-30 01:55 AM
2011-03-30 04:36 AM
rob2218 wrote:After you install BIM Server Manager from your CD, you MUST run the latest hotfix again to update the just-installed (and thus out-of-date) BIM Server Manager.
OK...so if I get the original CD, install the BIM Server MANAGER program on my Mac station...then could I access the bim server files??...what do I have to do to make sure that the BIM server manager program on MY Mac is accessing the files off the server??
Also...only reason I'd like to be able to call up the BIM Server Manager program is so I can manage the projects, users, etc...from my machine without having to go to the BIM Server physical location all the time.
