Scott Bulmer
BIM Server 14 - share AC13 file
I have BIM Server 14 installed and attempting to share an AC13 project. In doing so I receive the following warning message: 'Your client is not compatible with the selected server, server version 14....client version 13...'
I have successfully shared 14 projects. What am I doing wrong?
Thanks, Scott
AC27 v. 4060 w/ MEP, Cadimage, Twinmotion 2023.2.2 using AC from AC6.0, 2021 MacPro M1 chip, Adobe CC. Used AC on both platforms.
2 Replies 2
Aaron Bourgoin
The AC BIM Server is a modular affair that looked for the existing AC13 BIM server and created a 13 module to deal with those projects. Can you do an additional install to get that 13 module up and running?
AC14 required that AC13/NIM Server be patched to the latest build to pull this off.
The different modules use different ports as well. AC13 original group and new ones for AC 14.
Think Like a Spec Writer
MacBook M4Pro - 24Gb RAM
AC4.55 through 30 / AC29.2.1 COLLABORATE AC30.0.0 COLLABORATE
Rhino 8.36 Mac
MacOS Tahoe 26.6.2
Scott Bulmer
Hey Aaron, thanks for the reply. I am not sure what I did to possibly screw this up. I did install hotfix 3600 to 13 prior to commencing the 14 install. I followed the on-screen instructions for 14. Perhaps I missed something. I can see that only server module 14 is available in the BIM control center. So what is the recommendation to load the 13 module?
Restated; where can I read about how to install the 13 module to the BIM Server that already has the 14 module up and running?
Thanks again, Scott
