Gus
BIM Server file size clarification
File Sizes are different on BIM Server display. I have two questions about this:
1) Why the difference in file sizes here?
2) Are these file sizes too high?
Any thoughts would be greatly appreciated.
-Gus
See attached image.
www.michaelgustavson.com Architect NY WI IL
Madison WI
Archicad21 MEP EcoDesSTAR Win10-64-bit
EliteBook8570W [email protected]
QuadroK2000m RAM32 (2)250GBSSDs
4 Monitors Internet:4Up60Down
1 Reply 1
I don't know if those sizes should be the same or not.
Maybe the file on the BIM Server is uncompressed, while the backups are compressed which can explain the huge difference.
Also, I know that the BIM Server stores data in a different format so that could be an answer to the differences in sizes.
700 MB seems like a pretty big ARCHICAD file. I think you can check whether this is the case: open the BIM Server project on your computer and then save it as a PLN on your computer, then you will see how large that would be as a Solo file.
These are just thoughts that come to my mind when thinking about this, so don't take these are cold hard facts.
