Achille Pavlidis
BIM server not launching!
We have recently installed the 17 module on the BIM server, and after a server restart the BIM server control center does not work.
The icon on the dock does not react when clicked on, and launching the app from the folder does nothing as well.
What to do?????
Mac OS 26.4 | AC 29.2.1 INT 5101 FULL
5 Replies 5
Ed_Brown
Graphisoft Alumni
Graphisoft Alumni
Achille,
Please verify that you have:
  • com.graphisoft.BIM Server.plist
    com.graphisoft.BIMServer.plist
in the /Library/Preferences folder of the computer that hosts your BIM Server.
Also verify that you have:
  • com.graphisoft.TeamworkServerMoniotor-v17.0.plist
    com.graphisoft.TeamworkServerManager-v17.0.plist
    com.graphisoft.TeamworkMessagingServer-v17.0.plist
in the /System/Library/LaunchDeaemons directory. You should also have similarly named plist files in this directory for each module you have installed.
If you don't have these files, then your installation should be repaired from the install disks.
Graphisoft Technical Support
Achille Pavlidis
Ed,
I searched for the files, and they were missing.
(I suppose you mean LaunchAgents where you say LaunchDaemons)
I repaired the install and updated with the hotfix.
Today after a server restart the files are still missing and the BIM server does not work, giving me the following error message:
I re-repair the installation and updated with the hotfix, and now the BIM server is working properly, BUT the files are still missing!
Why is this happening?
Ed_Brown
Graphisoft Alumni
Graphisoft Alumni
Achille,
(I'm glad your BIM Server is running)
Do note: there are two "LaunchDaemons" folders:
One is /Library/LaunchDaemons
The other is /System/Library/LaunchDaemons
You should have both folders on your Mac. I don't think Mac OS X will run without the plists in the /System/Library/LaunchDaemons.
The teamwork plists will be found in the /System/Library/LaunchDaemons. I'm guessing you were looking in the other folder.
Anyway, I'm glad your BIM Server is running.
Ed
Achille Pavlidis
Yes you right Ed,
I was looking at the wrong folder...
Achille Pavlidis
Ed, every time we restart our server, the files in the /System/Library/LaunchDeaemons directory, keep disappearing, and we have to re-install BIM server every time...
why is this happening????
