BIM server setup - Help please
howdy
i have read through the forums and i am still not sure if the way that i propose to setup the BIM server is ok
we are currently running archiCAD v19, 11 and 12 but will be upgrading to v16 / v17 this week
so.. any help / insight would be greatly appreciated
our server room is setup as follows:
- mail server: 1 x mac pro running an email server (kerio)
- ftp server: 1 x macMini running ftpServer software & the archiCAD net key
- file server: 1 x mac pro running 10.6.8 server with file serving and dns as the only two services running.. this machine also has a couple of external RAID enclosures with all of our projects folders / backups etc
i was hoping to run the BIM server software on our file server... and have it use our existing folder / file structure.. is this possible.. or do i need to run it on a separate machine.. and have a file / folder structure setup just for it
if i can use it.. are there any memory, speed, stability, security, hardware / software issues etc etc that i need to be thinking about / dealing with
thanks again for any help / insight you can provide
yukioMishima
14 Replies 14
Eduardo Rolon
If you have a myarchicad.com account you can download it there. If not check your private messages in a little while, i'll send you the link.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
eduardo
HUGE thanks for the link... i am downloading the app now
have a great day
thanks again
yukioMishima
so
downloaded (thanks again ) .. however.. am getting the following:
warning!
your client is not compatible with the selected server
server version: 16.0.4010
client version: 16.0.3006
however... there doesn't seem to be anyway to upgrade the client
any tips / tricks on getting them talking with each other
thanks
yukioMishima
Eduardo Rolon
You need to run the latest AC patch again so it can update the client.
http://www.graphisoft.com/downloads/archicad/hotfixes/index.html
AC29 US/INT -> AC08
another Moderator
eduardo
awesome stuff... HUGE thanks
all sorted
have a great day
yukioMishima
