BIMcloud Server Issue: "Server is accessible, but is using an invalid certificate"
We are experiencing an issue with our BIMcloud, "Server is accessible, but is using an invalid certificate." Our team members are able to connect to the BIMcloud but can only access the file in offline mode.
A screenshot of the network diagnostic is attached below.
I have tried disconnecting and reconnecting to server. ArchiCAD is up to date. This issue is being experienced by our entire team (4 people), all go whom are connecting from different locations. The BIMcloud server was working as recently as 12 hours ago.
Any help on this would be greatly appreciated as we are pushing for a big deadline.
Thanks!
Joe
8 Replies 8
Noemi Balogh
jbrookover wrote:
Thanks!
Joe
Hi Joe,
Unfortunately we have a global issue at the moment. We are working to get a solution as soon as humanly possible. I suggest to try to install a temporary BIMcloud and move this project there, so you can finish the project in time.
We are terribly sorry for all the inconveniences.
Best regards,
Noémi Balogh
Senior Community Expert, Admin
Thank you for your quick reply Noémi.
By "temporary BIMcloud" do you mean setting up a BIM server on a physical local computer?
Best,
Joe
Noemi Balogh
Yes, I think this is the fastest solution I can offer you at the moment.
I recommend to check out these materials, they have some guides how to set BIMcloud if all of you are working from home: https://helpcenter.graphisoft.com/knowledgebase/126774/
Noémi Balogh
Thank you Noémi, we will pursue this solution and see what we can pull off.
Noémi, is there an estimate on when the service may be back online?
Noemi Balogh
It is unclear yet, we will keep you posted.
Noémi Balogh
dsenft
One of my remote users is getting that same message when trying to come into the BIM server here in my office (v25). Was this ever fixed?
Noemi Balogh
This issue was about BIMcloud as a Service and I can happily confirm we fixed the issue last year.
If you experience a similar issue with BIMcloud Basic, it worth to contact your support, or start a new thread with your question.
Noémi Balogh
