2009-05-12 08:53 PM
2009-05-13 06:07 AM
2009-05-13 02:18 PM
2009-05-13 02:20 PM
2009-05-13 02:22 PM
PivoArch wrote:Not the issue here...
That usually happens to me when someone else is trying to send/receive their file at the same time, or when the file is in that limbo period after the send/receive but before you can see the sign in window. Usually just waiting and trying again resolves the issues.
2009-05-13 02:45 PM
2009-06-10 01:25 AM
2009-06-10 01:41 PM
2009-06-10 02:35 PM
dirty wrote:This is exactly what is happening here in our office. The machines we are using are exactly the same. And yes, I have tried saving it as a solo, then re-sharing, the saving it as a solo again, and re-sharing again, even changing the name of the file whilst doing it, nothing fixing the problem.
We've been experiencing the same issue with a number of teamwork files in our office. It started happening again today on a relatively new project file. Both team-members have identical hardware, and as far as I know, the same settings.
It tends to happen more readily if waiting longer between hitting the 'Send and Receive' button. Occasionally the process leads to a message that says, 'Input File is Incorrect or Memory Full - I/O Error'. Then if you click 'Okay' then choose 'Ignore Error and Continue', the file crashes and reopens. Once the other team member sends and receives, the changes in the draft are able to be incorporated into the main file again.
Yes to it being a major distraction.
2009-06-10 10:19 PM
