felcunha
Can't install BIMcloud under Windows 10
Hello all,
I've tried to install BIMcloud 2018.2.1 under Windows 10 (version 10.0.15063) but I've got an error message saying the software is not compatible with this version of Windows 10.
I precise I'm running as administrator.
Thanks,
Felipe Ribeiro Cunha
AC 26, macOS Monterey
3 Replies 3
Noemi Balogh
Hi Felipe,
I'm Noémi Balogh, Technical Support Engineer from GRAPHISOFT HQ.
I sent you a PM to investigate the problem.
Kind regards,
Noémi
Noémi Balogh
Staff Community Expert, Admin
Noemi Balogh
Hi all,
We couldn't find the reason of the issue for Felipe (we would need to do a remote session, but for security reasons we are not allowed to do that), but he found a workaround. If anyone else having a similar issue, please let us known and we will contact you in PM.
Thank you.
Kind regards,
Noémi
Noémi Balogh
cagarruta
Hello Noemí, I am in The same situation ¿could you mind contact with me and explain yours worrkaround?
Joaquin
nbalogh wrote:
Hi all,
Thank you.
Kind regards,
Noémi
Archicad 25 SPA v6000
i9 14900K/32 Gb DDR4/1TB SSD/10GBPS Lan/Windows 11 PRO
