Teamwork & BIMcloud
Can't see BIM Server from AC15.
svpribyl
We upgraded a BIM server to 15. It is running on a separate machine. I am set up as a user. If I try to access the BIM server from AC15, the "Open/Join Teamwork Project" dialog box does not show any BIM Servers.
I can access the version 14 modules from AC14 on the same BIM Server. For some reason, AC15 can't see the BIM server.
The BIM server is visible to someone else on the same network running on Windows. This is a local network only-not trying to access it over the internet.
BIM Server is on a Windows machine. I am running MAC OSX 10.6.8.
Any suggestions what I might try?
Thanks
Steve Pribyl
MAC OS Sonoma 14.5
ArchiCAD 28
svpribyl
Repairing the permissions on the client machine solved the problem.
Thanks, Steve!
Steve Pribyl
MAC OS Sonoma 14.5
ArchiCAD 28
svpribyl
I'm still having this problem, as it turns out. Repairing permissions no longer works. Is anyone else having this problem with OSX 10.6.8? I tried accessing the bim server from a machine with OSX 10.6.7 and it works fine. I'm wondering if it's a system software incompatibility. I reinstalled the system software and still have the issue.
Thanks
Steve Pribyl
MAC OS Sonoma 14.5
ArchiCAD 28
