2024-03-12 07:53 AM
I have BIMcloud SaaS group with 8 member. They have "Full access" role now and i like to change it to self made custom role ....i can't find where i can set that custom role active for group?
Solved! Go to Solution.
2024-03-12 08:56 AM
If you want to grant your custom roles to the members, the easiest is:
Keep in mind that the members should have visibility permissions over the files, else no matter what permissions you gave, they can't use them (as they can't access the files). I also strongly suggest to keep the default permissions and don't delete them unless you're 100% sure on what you are doing. Else, you can easily lock out yourself from your BIMcloud.
Noémi Balogh
Staff Community Expert, Admin
2024-03-12 08:56 AM
Noémi Balogh
