Hi Guilherme.lima,
without knowing the exact Specs of the Systems it will be hard to find out whats the Bottleneck here.
Your Signature is a good Place to let us know this.
Some random thoughts:
- Check your AntiVirus Settings (and Windows Defender Settings) on both Clients and Server
- Make Rules (exceptions) for all Processes (Client and Server) and see if it helps.
- Isolate the Services & Processes on the Server side so that the Server just needs to handle CAD (no Fileserving, OneDrive, AnyDesk Task etc).
- Check if there are unused drawings, dwgs, things in the Project.
- Remove unnecessary Users from the Project
- Check when Backupscripts run on the Server
- Check if your System has exotic pagefile swapping settings
- Try to set it to "system managed" if not already
You might want to consult someone who can take a deeper look into your Setup
Admin of BIM [Cloud] [SaaS] [Server] | AC 19-25 [Win&Mac Clients] | VM's
